Is it possible to use a MOVE_INT block to initiate a subroutine CALL block? for example, i have several CALL blocks and i want to use a MOVE_INT block to specify the sequence of calling each of the CALL blocks i.e. on the input of the MOVE_INT block i will have a subroutine been moved to the output of the MOVE_INT block which in its case would be the MASTER SEQUENCE (%MW00105). This is been done on an RX3i GE Proficy Machine Edition.
