Using a MOVE_INT block to specify subroutine CALL blocks sequence
Taiwo88
Mar 2015
Glasgow
Is it possible to use a MOVE_INT block to initiate a subroutine CALL block? for example, i have several CALL blocks and i want to use a MOVE_INT block to specify the sequence of calling each of the CALL blocks i.e. on the input of the MOVE_INT block i will have a subroutine been moved to the output of the MOVE_INT block which in its case would be the MASTER SEQUENCE (%MW00105). This is been done on an RX3i GE Proficy Machine Edition.
If I could understand what you want to do maybe I could answer more clearly.
To do what you suggest I would recommend that you look at the Shift Register (SHFTR_WORD) or Rotate (ROR_WORD) Register function blocks, there are others that will work too.
In Proficy ME open the 'Toolchest' and select the Drawer for the type of logic you are using like "LD Instructions" and expand the "Bit Operations" then select the different blocks and press F1 to see details of how they work.
Good Morning , I appreciate your help on a previous post.Your advice helped me understand more. My next question involves the same project...
3,561
Good Morning , I'm trying to move a total for a dose into a dose history. I'm able to get my totals to move just fine. I would also like to...
2,407
One of Rockwell engineer had visited our site and activated rockwell software with the help of move 32 bit activator. Now I want to move the...
4,920
Hi, I posted not long ago regarding my setup. I took some recommendations, but I'm stuck good. Sorry if it's lengthy. I have an AB Ultra 200...
28
5,687
The class I am taking is currently attempting to do a stoplight program using RSLogix 500 Pro, with Allen-Bradley SLC 500 model 1747-L40B. The...
7,968
