Timer TON ??
richleva
Sep 2012
ontario
79
Hello again,
Probably a noob question. But I built program and the Timer is not counting?
nothing is happening? Bit B3:21/10 is enable
I made the that subroutine instruction is placed in the main program.
But my first timer T4:8 wont do anything? what am I missing?
Thanks again!!
Picture Is attached
Is the ladder file active?
Is the timer set elsewhere?
What resets the timer, apart from the "control bit" going off?
I believe it is active? once the subroutine is in place, Right?
the timer is not anywhere else
see the rest of my program, Picture attached.
That's all there is !!??
I am looking for CPU 363 but it is not easily available. Can i replace CPU 363 with any one the following?
CPU 350
CPU 351
CPU 352
CPU 360
CPU 364 and
CPU 374
Please guide.
I just want to put new CPU and download program in it. No further work i want to do
Which CPU is suitable to replace with CPU 363?
Thanks in advance
You should have started a new thread, especially since this thread deals with an Allen Bradley PLC and your question is about GE.
As long as the program is small enough to fit in the memory of the other CPUs, it should work OK. CPU350, CPU351 and CPU352 don't have as much memory as the CPU363. Also, if you are using either of the serial ports on the CPU363, you will be limited to the CPU selections with serial ports (CPU351 or CPU352). Note that the serial port on the Ethernet CPU models is only for firmware updates and not for communications with HMIs or other external devices.
Thank you for your quick and kind reply.
Yes the program is not big enough. Also the port on power supply is being used to upload/download programe in CPU.
Hello everybody, Since my experience is mainly with AB ladder I am having little bit of a problem with EasySoft.. Does anyone knows is there a...
831
Does anyone know of a library that already has a implemented RTO? I was going to write my own but I'd rather not take the time.
35
11,329
Hi there i was wondering if we can change in the TON the ms to min..... or how can i make a transformation... that shows up in c-more. cuz I am...
2,149
All, I've got a TON that keeps resetting itself even though the rung remains true, I've slammed my head over this for some time now and cant...
4,651
Ok guys I have a strange one. I just added a timer to to ML 1400 program, and it is not accumulating anything. But the OTE after the XIC TT...
2,001
