Eaton EasySoft RTO timer?
Ajaj1976
Nov 2023
GA
Hello everybody,
Since my experience is mainly with AB ladder I am having little bit of a problem with EasySoft..
Does anyone knows is there a something comparable to RTO timer?
Thx!
It depends on which Smart Relay you are using, they have different abilities and different ways of setting retention through the range.
Run a 1 second timer when enabled
At DN count a counter or add 1 to an integer and reset the timer
To reset the RTO just zero the integer or reset the counter.
I have worked on platforms where I had to create my own RTO and TOF timers, plus create Timer.TT and Timer.EN bits.
Here's how I have done it.
I made 1 change that the timer loops always and I CTU if the output is on.
The above way there would be a little lost runtime every ON/OFF cycle.
With the way here there is a slight gain every ON and loss every OFF, but over the course of a year actual code like this was off only a few seconds for a production machine that I had both ways in as a test along with a true RTO for comparison.
EDIT: Under the rung with the CTU I am showing 2 different ways whether you want it to reset when the output turns off immediately, or keep the count and reset next time it starts
Hello all, I am currently doing a project for a client. Where they want a custom claw machine built and programmed. The ask is for there to be...
2,269
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
119
Hi everyone: we have Baumuller AC drive BM4463 300A 160KW, it drives Baumuller AC motor DST2-315BO54W-020-5-A (90KW;RPM 200; 365V; 215A;83Hz)...
361
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
514
Hey everyone! So I'm trying to get different data from my Eaton DG1 VFD to my studio project. So far my research has led me to something called...
1,559
