MicroLogix 1000's and WiFi
Discal
Aug 2010
Florida
34
First off, I know nothing of Wi-Fi protocols as it relates to Automation. Sad to say I have never worked anywhere that it was in use. So I come to you with (almost) complete ignorance on this subject.
I was approached today by my manager, he says that the plant manager has suddenly decided that he wants to have about a dozen machines hooked up via Wi-Fi so that they can monitor run time. That is all well and good except... All of these machines have MicroLogix 1000's in them.
I know that I can install 1100's, I could also install a stand alone Arduino system. The list goes on and on I am sure.
What I was wondering, is there anything on the market that would be a simple; more or less, plug and play. I just need a single signal; on or off, that I can transmit wirelessly.
If you have read down this far, thank you for taking the time to review my problem.
Could also look into the advantech WISE line.. I haven't used those but I keep seeing them and have been intrigued.
Data-Linc Group had a device called the Net620 which was basically an EtherNet/IP to DF1 bridge. You could put one at every MicroLogix1000 and access them via EtherNet/IP. However it's not on their web site but the site is new and it's possible that they accidentally left it off. I'd reach out (http://data-linc.com/contact-us/) and see if they still have it. It's very simple to us and works well.
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
127
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,256
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
985
Hello All I am trying to convert a ML1000 program for use in a ML1400. I didn't create the original program & documentation is non existent...
4,409
Hey Folks, I have a customer with an older machine that is controlled with a MicroLogix 1000. The machine just quit working. The power light is...
22
10,561
