Phoenix Contact BreakDown
Avatar_41
Aug 2019
Istanbul
96
Hello I have a Phoenix Contaxt (ILB PN 24 DI16 DIO16-2TX - 2878146) I / O module that I control the inputs and outputs on the robot. Although I use it in 4 different robots, I always get malfunctions from the same robot. The Output module does not send signals. What could be the reason for this?
Phoenix Contact Cihaz problemi hk.
Merhaba,
Konu ile ilgili sorduğunuz soru bize Almanya üzerinden gelmiştir,
Kontrol edilecek ilk şey, her çıkıştaki LED göstergeleridir. Çıkış LED'leri yanmıyorsa, çıkış adresiniz PLC'de doğru olmayabilir.
LED'ler yanıyor ancak hala güç yoksa, tüm güç veri yollarının ve dönüşlerinin 24VDC ile beslendiğinden emin olun.
24VDC, hem konektör 1 hem de konektör 2'deki 1.1, 1.2 ve 1.5 numaralı pinlere bağlanmalıdır. DC ortak, hem 1 hem de 2 konektörlerinde 1.3 ve 1.6'ya kablolanmalıdır.
I am stuck on fail ctrl error 1013 cannot get IP nor can do firmware update need help pls urgent
170
Hi, I'm working with a Phoenix Contact FL NAT 2304-2GC-2SFP Ethernet switch, I already set the IP address and it has been working fine. I can...
1,275
Hi all, Historically i have used AB compactlogix exclusively working within the Logix/Studio5000 environment. I have decided to step out of my...
1,881
Hi all, first time poster and working on an existing PC TriSafe PLC for the first time for a project. I am wondering if anyone would know if...
1,115
(Rant)(CAD Models): Phoenix Contact Took the Time to say "FU!!" to their customers So obviously they have real CAD models of their parts because...
1,759
