Delta PLC - HMI
ktmtragic
Jan 2013
Sydney
92
Hi hope someone can help. I have done a fair bit of programming on Delta PLC's. I have a customer that would like a machine upgraded with a PLC and HMI. I have spent some time looking at examples and documentation.
My question is if a push button on the HMI is designated as input X1 is it allocated the address of X1 in the PLC, even though this is normally a field input on the PLC? Should the M bits be used instead? Any help understanding the i/o conventions on the HMI would be good
Thanks for this post guys
use m bit
will it be internal memory,parameter or link to DVP PLC
Also will one need to open the programme made on HMI with ISP SOft as well??
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
36
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
567
Hello, I'm facing a problem in communication between my delta TP70P-32TP1R HMI and DVP20EX2 PLC. I tried multiple ways in order to set the...
1,333
Hi! I'm an intern and a newbie in the field of automation. I was given the assignment to learn and program a PLC and HMI together. PLC: Delta...
1,974
Hi great Friends. I used a Delta HMI (DOP-B) series connect to a Delta PLC (DVP- EH) model....both hooked up on a wire drawing machine. Both...
1,675
