Siemens HMI with two network cards
rQx
Oct 2010
Trelleborg
1,051
A customer wan't to connect to my HMI and run VNC on his side, he doesn't however want to connect to my network in the control cabinet.
Is there any Siemens Panels with two Ethernet ports that I can configure individually?
Or how do I achieve this?
/Tim
I think that the new unified panels have independent ports. But that would require that you changed to WinCC Unified. I would not jump on that wagon - yet.
Consider to install a router in your system for your customer to connect to your system.
Actually, I dont understand why your customer cannot setup a router on his side.
I don't know how my customer has the site setup (I'm only supplying the control cabinet).
With your answers I can move along and know that there are several options for this
Thanks alot!
/Tim
Buona sera, Ho dei problemi nell' interfacciare PLC S5 con HMI 2a Gen. Siemens (ad esempio KTP400) tramite IBH Link S5++. il mio obbiettivo è solo...
112
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
327
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,480
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
173
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
600
