It appears that the OP is polling the data once every 3 seconds or thereabouts, It is not clear what data is stored, at this time it's just a matter of conversion shown is every scan just to get it into float format, It is an interesting point about history, with the FX3, memory is limited to 32 k words, so perhaps only a limited storage, normally about 14 blocks that's 7k of retentive memory in the "R" registers, there is a limit using a shift register or block copy to 512 words so in effect 256 reals, so would have to be shifted 4 times as the function is 16 bit only. for each 1k of reals.
No idea about the HMI, perhaps it has logging functions or at least some sort of file handling.
This is also a clone of the FX3U, not sure if it has the same functionality, often they do not, some of the real cheap ones you cannot alter the PLC parameters which means unable to use the R registers where these have to be setup.
It is also possible that not all in-built functions will work again, some of the clones the firmware has not been updated so functions that work on FX3U Series C may not work.
