1769-SDN with 1791DS-IB8XOX8
tdiponio
Jan 2012
Ontario
Hello,
I have a question about the Compact logix Devicenet scanner 1769-SDN.
Can I add a Safety module (1791DS-IB8OX8) to the I/O config? If not, how can I map the safety inputs from this module into my Safety Task?
Thank you :)
Welcome to the PLCTalk forum community !
In general, DeviceNet safety I/O modules are configured entirely inside Studio 5000 Logix Designer, as part of the "IO Tree" under a 1756-DNB. This is unlike ordinary DeviceNet devices that are configured and mapped into the Scanner's scanlist.
But to my knowledge, the 1769-SDN does not support safety I/O. You can use a 1788-EN2DN to bridge CIP Safety modules on DeviceNet to a Compact GuardLogix, but not the 1769-SDN, just because the 1769 architecture doesn't support CIP Safety.
I'm taking that in part from my knowledge of the older Compact GuardLogix, and in part from the Knowledgebase:
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/66915
All Found myself in a situation where I need to flash the 1769_sdn Devicenet module from 2.002 to 4.004. I uploaded from the module but it has...
2,383
I am working on upgrading a system with a ML1500 that uses a 1769-SDN DeviceNet Scanner to a CompactLocix L24ER-QB1B. Due to cost, I need to...
1,403
Hi anyone, We have a DeviceNet scanner 1769-SDN that is putting out " 08... Er" on the display. Anyone know what that means? We are not able to...
1,739
I am using CLX L35E PLC. There is a 1769-SDN module in slot 1 of this PLC. When I want to view the devices over RSlnx, all devices are displayed...
1,533
Hello, I'm trying to replace a 1769-SDN devicenet scanner on a compactlogix system. The issue i'm having is when i replace the scanner and...
1,885
