S7 PLC Simulator problem with SFC20
Werner
Apr 2005
IJsselstein
336
Maybe you already know this but I just found it out.
I tested my program using the PLC simulator from siemens (S7). In this program I use SFC20 (BLOCKMOVE). When simulating it all worked perfect.
On site at the customer I found out that it didn't work. (You can't use SFC20 if the source and destination overlap, which I had done). So I had to change my software onsite. So I guess I will now test complicated programs always on the real thing.
Werner,
90% of the simulators I tested showed the same behaviour: there's always something, sometimes small, sometimes big, that behaves not exactly as the real thing does. That's why I stepped away from simulators years agoo. The only one I still use is professor Bill Simpson's LogixPro program found on the learning pit. But then again it only covers part of the possibilities you have with the real thing (AB SLC). I'm very excited about Phil's simulator, I surely hope it can match LogixPro's abilities.
Kind regards,
Werner,
I would forward that bit of information to Siemens.
If we are lucky they will make an update to the simulator.
I use the S7 simulator a lot, and it saves a me a lot of trouble when commisioning the real project.
in this simulator if u adjust cpu clock time by manually (for example to 19:59:57) clock's hour segment doesn't increase; instead of it minute...
2,187
i've been using s7_200 simulator (canal plc) for a long time. it was useful for to simulate basic functions of s7-200 plc. but recently my...
8,073
Showing a new guy basic programming and remembered the simulator here. But nothing happens when selecting the link. "Try our online PLC Simulator-...
25
1,620
hi everyone please give me a solution to timeout error in delta plc simulator,i have a doubt about firewall and antivirus we r using.
772
I just started to learn how to program PLCs. I was searching for the best simulator programs for learning how to code PLCs. The best one I could...
3,129
