Simulation works With CPU 1500 and doesn’t work with 1200 why ?
Any name
Jul 2018
Dubai
21
Hello,
I’m developing a program and i found that my simulation works very well when i use CPU 1500 but when i use 1200 and i click download. A PG/PC window pop up for me and when i try to search the address to start loading it give me an error say that no compatibility. Why ?
Thank you
This is very very light on information. You haven't told us what TIA Portal you're running, how you change from S7-1500 to S7-1200, is it a new project, do you start a new instance of PLCSim, etc...
Do you care to give us more information?
I’m Using TIA Portal V13 SP1, Yes i was changing by starting a new project. What do you mean by “ Instance of PLCSim “
I hope what i gave you now is enough.:D
Do you start PLCSim, then open your S7-1500 project, test it, then open your S7-1200 project and try to download to PLCSim?
This means that PLCSim, is already configured as a 1500 and won't reply as a 1200.
Additionally PLCSim has a selection for which type of CPU you want to simulate. Did you choose this?
I’ll explain the whole situation. I was working on a program using S7-1500 and everything was going great. Today from the second i turned on my PC I decided to try 1200 that’s mean i didn’t use 1500 Simulation at all. I found that i couldn’t connect it to PLCSim and the other thing is that i can’t use STL in Main OB to call the program.
Yes i used the option PLCSim 1500/ PLCSim1200 and i couldn’t connect it.
1. What is the cat number / firmware version of the 1200? You need version 4 or greater for PLCSIM.
2. Not certain if TIA V13SP1 even supports PLCSIM for 1200 CPU.
3. S7-1200 does not support STL
It supports v4 but he would have to install an HSP
78
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
70
hello every one. i'm new to tiaportal, i have created new project and HMI screen the program works fine with PLC-sim, but when i try to cntrol the...
409
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
644
I use the HMI simulation as our production lines are pretty big and we've put an upgrade in over the last couple of months and I've used it most...
730
