SoMachine (Codesys based) Online Simulation Question
KHadley
Aug 2018
Riverside, CA
Hello!
I think I have a basic question and I'm hoping someone can point me in the direction of a solution.
I am new to PLC programming and my tool of necessity, SoMachine. I'm trying to test simple lines of logic (turn on and TOF a single lamp).
[/url][/IMG]
I enter online simulation mode, start the controller, and change the preset value of iStart... and nothing happens.
I feel like I am missing a key, and very basic, step (or understanding of how the simulation process works). I am almost embarrassed to ask, but I don't have any resources to tap in to. I've tried searching this forum, Google, and Youtube. Maybe I don't understand the software well enough to identify the correct search terms.
I'm good at eating crow, so fire away!
Thanks!
Keith
Solved
Hello All,
My Schneider rep finally got back to me, as expected, the solution was extremely basic. I was changing the "Prepared Value" and expecting the logic to execute, but didn't realize that I needed to select "Write Value" (CTRL-F7) to actually change the value.
Sorry for the basic question. Maybe someday someone with the exact question will find my experience helpful.
I have to modify a PAC drive lmc controller so that an external scada can acess some tags. The scada integrator asks us to make does tags...
1,602
Hi there, I am trying to develop an application using the somachine software, however have come across a drama. The 'AlarmManager' function isn't...
2,968
Hello, I am fairly new to plc programming and am now tasked with converting the company software standard from Siemens TIA Portal to SoMachine, or...
2,997
Hi guys Using somachine 4.1 sp1. When i run the web vizu in chrome i get an error that your browser doesn't support html5 canvas. Even though this...
3,778
I'm trying to run a transition off a Boolean variable. This variable is two other global variable flags anded together in a separate CFC POU. In...
29
8,622
