SoMachine/CoDeSys Alarm Manager Library
louispijpers
Mar 2010
Toowoomba
Hi there,
I am trying to develop an application using the somachine software, however have come across a drama. The 'AlarmManager' function isn't provided in the somachine software. I have found the library and added it in but am unsure how to add it to my application & and use it in the webvisu development
Please see screenshot below.
Has anyone found a work around for this-other than writing there own alarm handling function?
Regards,
Louis.
I'm having exactly the same issue. I have found in help section that alarm functions do exists, but i can't use them neither.
I've asked my schneider partner and found no response at the moment.
Does anyone found a solution for this?
When I last used Somachine the alarm manager was not supported by somachine. The manager is native to codesys but schneider has removed it from their software. That is why you still find articles about it in the help file.
I had to use dynamic text lists to create an alarm banner in the webvisu
I have to modify a PAC drive lmc controller so that an external scada can acess some tags. The scada integrator asks us to make does tags...
1,596
Hello! I think I have a basic question and I'm hoping someone can point me in the direction of a solution. I am new to PLC programming and my...
1,653
Hello, I am fairly new to plc programming and am now tasked with converting the company software standard from Siemens TIA Portal to SoMachine, or...
2,988
Hi guys Using somachine 4.1 sp1. When i run the web vizu in chrome i get an error that your browser doesn't support html5 canvas. Even though this...
3,760
I'm trying to run a transition off a Boolean variable. This variable is two other global variable flags anded together in a separate CFC POU. In...
29
8,610
