SoMachine and codesys tag acess
matwon
Mar 2014
Québec
I have to modify a PAC drive lmc controller so that an external scada can acess some tags. The scada integrator asks us to make does tags available through codesys... I'm not sure what he means. Anybody got any experience with somachine that can explain me what he is talking about?
Thanks!
Are you the original provider of the motion controller ?
A "PacDrive LMC" is probably one of the versions of the PacDrive 3 "Logic Motion Controller", maybe the Pro/Pro2 or Eco models.
These controllers are of course based on the CoDeSys architecture for PLC logic control and motion control.
My guess if someone said "make tags available via CoDeSys" would be that they wanted specific tags created in the Global scope so they can be read and written by software that has a CoDeSys tag driver.
Or, they might be asking you for an OPC or OPC-UA connection to specific data in the drive.
The more context you can provide, the more folks might be able to help.
Hey guys,
They will be using a Kepware server with the codesys driver. The tags are indeed in the global scope.
Hello! I think I have a basic question and I'm hoping someone can point me in the direction of a solution. I am new to PLC programming and my...
1,651
Hi there, I am trying to develop an application using the somachine software, however have come across a drama. The 'AlarmManager' function isn't...
2,954
Hello, I am fairly new to plc programming and am now tasked with converting the company software standard from Siemens TIA Portal to SoMachine, or...
2,986
Hi guys Using somachine 4.1 sp1. When i run the web vizu in chrome i get an error that your browser doesn't support html5 canvas. Even though this...
3,759
I'm trying to run a transition off a Boolean variable. This variable is two other global variable flags anded together in a separate CFC POU. In...
29
8,610
