existing 1783-NATR - Can not ping ?
EICS
Dec 2008
Melbourne, Australia
323
i have an existing 1783-NATR on site i have added another 2 addresses to the table.
addresses are typically 10.15.35.x on Public Side and 192.168.0.x on Private side
so i added a translation for 192.168.0.103 as 10.15.35.136
am i correct that if i try to ping 10.15.35.136 "across" from the Public side to the Private side that command prompt cannot access it?
i tried this but it did not work, i seem to remember this is the case from CMD.
whats a good tool to test my config ?
In my experience the device that you are trying to ping must have a gateway address or the ping will fail. I believe the gateway address should be set as the ip address of the Natr on the private side.
If I am understanding you, you should be able to ping from cmd to the public IP, if you are on the same network. I can ping some of my NAT'd devices using their public IP.
Can you see the devices in rs linx?
Correct. You should be able to ping from the public side IF the device you are sending the ping to has a gateway address assigned. Again going off of memory, I believe the gateway should be the private side IP address of the natr. Try that.
Hello, I am fairly experienced programming and modifying existing FTView ME programs. I have also used FTView SE to make modifications to a...
131
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
596
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,209
Hello I am kind of new to the Rockwell world, i've mainly worked with Siemens and Schneider untill now. I am to make a HMI application running...
1,094
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,151
