TI 305 & dos based software
jonwayne1951
Jul 2006
SC.
Was able to download the ladder but there was a fault in the CPU saying the battery was dead but the light on the frount pannel didn't come on even with battery removed.
I purchased another CPU and tied to download program and can't get on line. using the SIMATIC TI30503dm interface. have it on an old dos laptop. using the original cable that worked just a few day ago. is there something funny about setting up the cpu to down load? Already removed battery to clear memory. Also now can't talk to original cup after the battery was removed. using com1 to adress 01
Jonwayne1951
using exact same computer with same cable and same settings just different results. downloaded the wiring for the cable and it checks out ok also
It could be that the rack/power supply is bad. That was always the component with the highest failure rate. There may not be enough power for the data communications unit.
Is the "PWR" LED on the face of the data communications unit lit? Does the "DATA" LED blink when the software is trying to establish a connection? Is the toggle switch on the right side of the data communications unit in the "Online" position?
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
416
I am looking at a 1305 drive connected to a PLC5 via RIO. The drive is working and I was able to get a functional HIM working on the drive as...
1,862
Hi Everyone, We do have several cabinets with SLC5/03 CPU's and two SCANport modules, each. 5 ports are being used, communicating with 1305 VFDs...
2,495
Hi, Just looking for a quick pointer. I want to upload an old program out of a Texas 305 PLC. The program was last downloaded in the 90s so...
2,036
i have 10 signals for 10 different tanks in service.how can i find out how many are online or offline at any time..... Thanks
1,337
