daviper1996
I am looking at a 1305 drive connected to a PLC5 via RIO. The drive is working and I was able to get a functional HIM working on the drive as well.
I see O:151/4 is forward and working as expected
I also see O:151/5 is reverse and the bit does come on in the PLC as expected. When /5 is made /4 is not and vice a versa.
However the drive always runs forward.
I know on newer drives you can block out reverse, but I am not seeing in the manual how this would apply to a 1305 drive via RIO.
I saw parameter 94 had a direction mask but again, I am not sure if that is where I should be looking.
Any advice would be helpful thank you.
