Data transfer from PLC SIEMENS S7-300 to personal computer data transfer
iv73nikolov
Jan 2007
Haskovo
What the software and the configuration of the PLC should be , if I have to transfer the values of several counters to a windows-based PC and create MS Office table with these data?
Hello "iv73nikolov"
I guess you are talking about an MPI connection. You didnt state what kind of connection.
One solution could be to use Simatic Sofnet S7 + a CP5611 card.
You would then use Simatic Sofnet S7 to create an OPC connection to the PC.
This FAQ describes how to use OPC with Excel:
http://support.automation.siemens.com/WW/view/en/24299099
Notice that Simatic Softnet does NOT work with the PC adapter ! That is why I suggest a CP5611.
Simatic Softnet PB S7 + CP5611 also works with Profibus.
If you have ethernet, then go for Simatic Softnet IE LEAN. You dont need the CP5611 then.
There are 3rd party OPC servers that do work with the PC adapter.
Hi all, I am working on a project that with need to capture force sensor data in footplates in order to determine if weight shift is occurring...
538
Has anyone here successfully created a system where the software SAP (ERP) interfaced with an Allen-Bradley PLC? Currently we have to take recipes...
1,139
Hello parky, goghie, Brian and all of you who kindly come to help when I get stuck. I cannot look into the clock issue that parki has written for...
886
Hi, If we have PLCs on different subnets is it possible to do TCP comms data transfer between them? I'm assuming if we use a routing switch and...
831
Hello folks, :) I'm new to the plc programming, and I have a question that would be great if you help in: I have a bit that goes high every time...
2,073
