opening a versa pro file in Proficy Machine Edition
moeen
Jan 2006
Sydney
29
Hi guys, Just a quick question, I have to open a very old GE versa pro file and I dont want to install versa pro as I have Proficy ME version 5.5 SP2 already installed. Is it possible to use this to open a versa profile, if yes please let me know how?....
Regards.
Create a new project with Machine Edition. When you right click on the PLC target in the project navigator window, the third item from the bottom of the list is "Import". Select "VersaPro Folder" and browse to the location of the project you want to convert.
Thanks Steve. Actually did a search in Proficy ME help and found the same instructions as you said. Thanks anyway.
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
64
Very similar issue as the last post I had here with communicating our Linux Gateway to an AB CompactLogix controller. I have assigned a gateway...
173
Hi All, I am trying to program some new Versamax micro PLCs through PAC using some programs saved in our archive however whenever i go to import...
123
Hello, I have a CNG compressor that is run by a PLC. I tried to get team viewer on it to be able to view it remotely, I accidently disabled the...
107
Hi All, I've been pulling my hair out trying to fix this for a few days and need some advice. I have V19.01, v20.05, V21, V24, V30, V31, V32...
409
