Siemens HMI & PLC different TIA Portal pojects version
maeu
Jul 2015
Mlawa
Hello,
I have a PLC programmed in TIA Portal V12. HMI for this system was also created with V12 but it broke and I was forced to upgrade project in WinCC V12 -> V13 (I don't have license for V12).
Do you know if it will be work (HMI project V13 with PLC V12)?
System is far away from my company and we plan to send HMI to client without visit so there is no uption to upgrade project in PLC to V13.
Hello,
It should work, but I've seen some squirrelly stuff with Portal project versions, so I'm never sure.
128
Buona sera, Ho dei problemi nell' interfacciare PLC S5 con HMI 2a Gen. Siemens (ad esempio KTP400) tramite IBH Link S5++. il mio obbiettivo è solo...
115
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
609
I'm a bit lost. I don't understand why my HMI (Simatic 1200) is not recognising any PLC tags. From the ethernet comms page , all seems OK. Yet...
2,259
Sorry for the basic question: At the moment, the PLC [S7-1200] is connected to a laptop (contains TIA Portal) via the ethernet port. When I add...
1,566
