Import PLC Code from Allen-Bradley PLCs to B&R Automation Studio
stefanF
Feb 2021
friedrichshafen
Hello guys,
iam planning to switch from Allen-Bradley PLCs to B&R PLCs.
Does anyone of you know if its possible to import the Logic in Automation Studio?
thanks a lot. your help is very appreciated.
StefanF
You don't say which platform is it SLC, PLC5 etc.
Assuming older models then there is probably no way to convert between different manufacturers only brute force, the reason for this is older platforms did not use IEC standards & ST which are supposed to be transportable, there are also the problems of special cards like analogue, high speed counters, coms etc. Even when converting modern platforms which use IEC, there would still be plenty of errors, from my experience, even converting from Siemens S5 to S7 was problematic, for example, special function blocks etc. So unless some bright spark has built a utility to do the conversion I would say it is unlikely.
If the logic on the RSLogix side is ST, then you should be able to copy-paste, but then you'll most likely still have to go in and manually convert things here and there.
If the logic on the RSLogix side is in LD, then forget it.
Good day colleagues, I have a problem with a plc slc 5 since I export the tags to my factory program to load them into a panel view 1000 plus 6...
114
Hello, We are looking at a machine upgrade project, for which we will probably use a Do-More BRX PLC + 3 high speed I/O modules, to automate...
710
Is there a way to import ladder files into a CLICK PLC? I'm usually an AB guy so I do a lot of Excel coding to create logic and import the logic...
2,746
Is there a way to export/import parse-able files of the PLC program of a Mitsubishi Electric (MELCO) iQ-R PLC? I am working with iQ-R PLC...
1,796
I'm trying to import a .prj file and I keep getting the error message: Project import error. i Any ideas how to get around this? Thanks.
73
