1783 natr cidr
Shlzy
Jul 2018
Sydney
Howdy,
Has anyone tried to translate different subnets on private to the one net on public with the 1783-NATR
Ie
Device 1 - 192.168.10.1 translate to 190.191.191.10
Device 2 - 192.168.11.1 translate to 190.191.191.11
I was hoping to use only the one NAT to read tags from 18 devices on separate subnets up to scada.
Can I supernet my private and translate only the devices I want to level 3?
Or will I need a NAT on each subnet?
Cheers
It depends on your SUBNET mask on your private network. If your subnet mask on your private network is 255.255.254.0, it will work because both address are in the same subnet. If the 192.168.10.x and 192.168.11.x address are different subnets, then i do not believe it will work because it is not possible for the NAT device to be connected to more than one private subnet. In that case, you will need a NAT device for each subnet or a more capable managed switch.
Thanks Helliana,
I was thinking along the same line with the subnet mask
But wasnt sure on the NAT being capable.
I have a spare NAT so i might try it on the rig and see what its possible of doing.
Is it possible to gather OPC data through a 1783-NATR? Searching around, it sounds like OPC data might be blocked by any NAT... Is there any work...
263
Good morning all, I have a project that has quite a few NATRs to configure. I would like to modify the generated backup config file because I...
467
I am trying to communicating with other PLCs on a public network from a CompactLogix PLC on a private network. I have installed at 1783-NATR...
575
Hello, I'm seeing some interesting behavior with my NATR connections on FTLinx. 2 separate cases are showing the same problem: The first NATR...
637
Hello, I have been trying to set up a NATR with 3 connections, I am able to ping the public IP of the NATR itself off of my network, but nothing...
707
