Manually set fault bit in Micrologix 1100?
toggle this bit... but also why do you want to?
EDIT:
I answered but I was wrong... I will keep looking
The easy way... cause a math fault and don't have an over flow protection
I have done that every time I write a program :)
This works for me BUT, remember if this PLC is working it will stop until you fix it (remove the logic) so you may want to use a N (integer) file that is not used in the program
Hello everyone‚ Fairly new to PLC prog I seek your advise concerning what is said in my thread title; I program using workbench components; I...
1,255
Hi, I've been working with Beckhoff TwinCAT for a small time now and I already know the basics. There are however few things I can't make out so...
4,845
Hello everybody, I’m there after a lot times and unfortunately I’m still beginner in PLC world but I don’t give up, this morning we are had...
2,335
To quickly test a plc output which is wired to a relay do I dob a cable between the output and 24vdc+ source I.e something with 24vdc+ live such...
693
Hi there, I am trying to determine the input, output, and config assembly and entering it into a beckhoff plc, and couldn''t get proper active...
22
7,369
