lazymonkeygod Member L Join Date Nov 2008 Location Home Posts 16 Nov 18, 2008 #1 Does anyone know how to manually set the fault bit for the Micrologix 1100?
geniusintraining Lifetime Supporting Member + Moderator Join Date Jun 2005 Location SC Posts 8,278 Nov 18, 2008 #2 toggle this bit... but also why do you want to? EDIT: I answered but I was wrong... I will keep looking Last edited: Nov 18, 2008
lazymonkeygod Member OP L Join Date Nov 2008 Location Home Posts 16 Nov 18, 2008 #3 I need to test the functionality of an opc server that I have for this device. Thanks for your help btw.
geniusintraining Lifetime Supporting Member + Moderator Join Date Jun 2005 Location SC Posts 8,278 Nov 18, 2008 #4 The easy way... cause a math fault and don't have an over flow protection I have done that every time I write a program
lazymonkeygod Member OP L Join Date Nov 2008 Location Home Posts 16 Nov 18, 2008 #5 how do you cause a math fault? sorry I'm not particularly familar with how this device works.
geniusintraining Lifetime Supporting Member + Moderator Join Date Jun 2005 Location SC Posts 8,278 Nov 18, 2008 #6 This works for me BUT, remember if this PLC is working it will stop until you fix it (remove the logic) so you may want to use a N (integer) file that is not used in the program
Mark Buskell Member M Join Date Sep 2003 Location Florida Posts 892 Nov 18, 2008 #7 Another easy way is to move a negative number into a timer preset.
Ken Moore Lifetime Supporting Member Join Date May 2004 Location North, West, South Carolina Posts 3,475 Nov 18, 2008 #8 I second Mark's recommendation, this is the method I use to test fault routines.
