1762-1F4 Analog Input
toarts
Apr 2010
San Jose, Calif
30
Hello Guy,
Sorry, this is my first time adding/configuring analog input model number 1762-1F4. I am using Micrologix 1400. I added this analog input into I/O configuration and setup all the parameters 0-10V. Since I dont have any sensor to test the analog input, I hooked up a voltage meter into analog input 1 perhaps I can see some values. But I think I am jumping ahead, is there anything else I should look into? also, in what address I should be looking at, supposed everything setup correctly? is it N7 data table hold all analog input?
Thank you so much for help.
:oops:
You may receive better responses by posting in the regular forum instead of the practice area.
The manual for the module, under 'I/O' Memory mapping shows the location of the information very well.
Hello Guys, Sorry, this is my first time adding/configuring analog input model number 1762-1F4. I am using Micrologix 1400. I added this analog...
3,318
Does anyone know what type of thermister for the CJC on a 1762-IT4 thermocouple card? I have searched everywhere and can not find. I can not see...
629
Hi every master,Recently i met a fault about 1762-L40BWA 1,When i get the PLC, The Fault light is lighting, I am not remember the fault message,I...
728
Hello everybody and master,I met a problem about ML1200.It is described as below: 1,When i got this PLC,The FAULT light is lighting, My computer...
1,129
I have 1769-IF4 module and 1766 micrologix 1400 series B controller, when connecting Analogue input in module it's showing maximum values of...
1,737
