Sequencer Exercise Problem
skingusmc
Jul 2006
Ventura County, California
I am learning PLCs, and we are using the SLC 500 and Micrologix 1200 at school.
We have a "sequnecer exercise" that our instructors has challenged us or any other instructor to find the problem, and then of course to fix it.
While I don't have PLC gear at home, I could "post" or "upload" the program for you to look at.
(How do I upload the program?)
I have "stared" at the program, and am just not getting any where.
Looking forward to "posting or uploading" the file so I can get your assistance.
Steve
Welcome to the forum.
To upload the program you will need to zip it using a program such as pkzip. At the bottom of the advanced post window there is a button to attach a file. You browse to the file on your computer and select it. When you submit the post the file will be attached.
When you submit, attach a brief summary of the problem and what you think you need to do next or explain what part confuses you. There are many of us here who are more than willing to mentor and help students who are looking for a nudge in the right direction, we just don't want to do your homework for you.
So far it sounds like you are making a good attempt at solving it, so upload your file and lets see where we can help you.
edit: Also, do a search on the forum for previous threads dealing with sequencers. You might just find your answer there.
zip the program...click on attach files
If I have done this correctly, the AB Micrologix 1200 PLC Sequencer program file is attached to this messaage.
One problem I figured out was that the program originally had only one "Control" location (R6:0), so I corrected that by having a different control for each pair of sequencers.
I have also thought that "masking" may be why one set of the lights (output)do not work when the lights (output) on rung 2 are on (true). I'm not entrily sure that is on the right track though.
As I watched the program run, it seemed that the output from rung 1 would "flicker" as the output on rung 2 would energize (go true).
I hope I have explained this so you can understand, as I am not completely familiar with all the terminology and just how to describe programs as yet.
Steve
This program only consists of rung 0. containing some anded inputs and 1-ton with 2-sqo's or'ed together. I do not see rungs 1 and 2 with the outputs you describe. Is this an incomplete program?
We still can not do much with this program for we do not know the values that fill the data tables for N7:0, N7:10, N7:20 AND N7:30
All -
Here are the "N" data tables in "Decimal" (if not listed the value is zero):
N7:0 - 0 N7:20 - 0
N7:1 - 192 N7:21 - 2
N7:2 - 1152 N7:22 - 4
N7:3 - 384 N7:23 - 8
N7:4 - 192 N7:24 - 16
N7:5 - 2112 N7:25 - 32
N7:6 - 576
N7:10 - 0 N7:30 - 0
N7:11 - 4 N7:31 - 4
N7:12 - 8 N7:32 - 8
N7:13 - 6 N7:33 - 6
N7:14 - 4 N7:34 - 4
N7:15 - 8 N7:35 - 8
N7:16 - 6 N7:36 - 6
At school we were using a MicroLogix 1200 which is wired up to a "panel board" that has various switches/push buttons and lights/horn for input/output.
The "outputs" (and position on the board)for the panel board are as follows:
0 1 2 3 4 5 6 7
Horn Green Blue Green Red Blue Red Red
Light Light Light Light Light Light Light
8 9
Yellow Yellow
Light Light
10 11
Green Green
Light Light
The idea is to have one sequencer turn on outputs (lights) 1 through 5 and then to have the other sequencer to turn on outputs (lights) 6 through 11. (lights 6 - 11 represent a "traffic light").
Once again, thanks for all your help.
Steve
The mask FFFFh is all ones so it should not inhibit any of the outputs (in the pdf it may have already been corrected).
The other problem is that the timebase is way too freaking fast for traffic to keep up with unless you live in Dallas or something.
Either change the values in the data table that are written by the SQO to the timer presets to higher values so grandma can get her minivan through the intersection, or change the timebase of the timers to whole seconds, or both.
(N7:10-N7:16 go to T4:0.pre and N7:30-N7:36 go to T4:1.pre)
The common control element was a good find on your part by the way. Very good indeed for a beginner.
Paul
I'm seeing some confusing descriptions on the Bit Sequencer (BIT SEQ) in the GE PLC instruction set and I'm converting one of these to AB so I...
1,863
Hello All, Im alot more experienced with the CLICK PLC - They have a pretty user friendly Sequencer in their ladder logic software - very easy to...
1,160
Hello everyone, stay safe at home, please. I'm looking for a solution in WPLSoft Delta in order to control 3 compressors boosters, attached...
25
5,495
Hello Everyone, I have just started exploring the Sysmac studio and I am not familiar with the instruction set of the sysmac studio.I am trying...
1,678
Hello All, I have a question regarding Honeywell HC 9000 sequencer function. I'm using this function to escalate energizing additional controls...
1,313
