Factory Talk View ME Runtime
Coulombboy
Jan 2012
Makati City
70
Hello guys. I just want to clear out if FTVIEW ME runtime is for running the HMI in the PC. Also, if it is for PC, can we configure the screen to have 1080 resolution? Thanks in advance for the answer.
Yes, the FactoryTalk View ME Runtime software and license will allow you to run a FactoryTalk View ME application on an ordinary Windows computer instead of a PanelView Plus terminal.
If you have FactoryTalk View ME Studio installed on a Windows PC, you can run the "test runtime" for two hours before it needs to be reset. To run the application indefinitely, you need the ME Runtime software and license installed.
FactoryTalk View ME can run on a PC with any resolution that is supported by the computer's video card.
"1080" generally refers to "Full HD" video, which is 1920 x 1080 resolution.
185
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
355
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
308
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
632
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
387
