Espon Robot And Control Logix
Donnchadh
Jun 2002
Ireland
1,004
Hi All
I am working on a project with a Epson robot and a Control logix plc.I am hoping to connect to the robot over ethernet.I have worked a lot with ethernet on plc to plc,plc to hmi but never to a non Allen Bradley device.Is this possible, would I need ehernet ip networks soft ware.The start and stop digital inputs to robot.We need to selected programs for the robot and I think this would be the best way,as I acn send a string message to the robot and it will read this.
Thank you for taking the time to read this
Donnchadh
Very easy and very quickly; just set IP adress and go!
Do you need some other help? Which software, drivers...
Regards,
MisaMark
Hi
Thanks for the reply.Do i need ethernet IP software or can I set it up in logix 5000
Thanks again
You need RsLinx to connect; he is "like" driver; you need to set up all parameters for communication there (RsLinx). After, you can use suitable software (Logix5000 or RsView... ) to make what you want;
But, for connection, just set up RsLinx
You can write me exactelly what actually you need to make; maybe I can help you!
MisaMark
There is two ways of communicating the Robot one is sheduled & otherone is unsheduled
To do sheduled connection configure the device in the i/O tree provide the assembly instances & Ip address in generic ethernet module
To do unsheduled connection prepare the msg inst with proper path & assembly instances
if connecting to an epson robot via ethernet/ip what are the assembly instances set for in the generic ethernet module. Or what are the settings for the msg?
It is a Allen Bradley Compact Logix 1769-L33ERM and and Epson Robot Controller RC180
hello, I'm a student and for my final grade I have to repare a sepro robot. the only problem I have for now is that i have an error code 3...
62
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
284
Hello All, I'm looking for some opinions and Ideas for guarding the product entrance of a palletizing robot cell. Please see the attached...
533
Hi all, First time posting here. I have a Omron NX1P2-1040DT controller that I intend to use for a small project. I also have a KUKA robot that...
1,233
Has anyone ever tried to integrate a Raspberry Pi to a Fanuc robot? I have this idea that I want to try out but I need to write integers from a...
1,598
