Apologies in advance if this is an ignorant question . A few years back the Rockwell literature for how to setup say a powerflex 527 showed an example where the the IP was set to 10.202.10.05 for example, and they showed the default gateway being set the same as the drive, 10.202.10.05. Then a firmware revision changed things so that became an "illegal address" which left us to fix something with the 5 faceplate buttons .
Some of our machines we ran into that because the existing drive was setup with gateway set to drive IP, we replaced the drive with new, and the newer firmware would not allow that setup.
Most of our stuff is setup 10.202.10.05 for drive, subnet 255.255.0.0 for subnet, and gateway then would be 10.202.0.1, if subnet is 255.255.255.0 then gateway is 10.202.10.1.
Ok so the question...are they actually USING the default gateway for anything on a typical machine network that might have say a PLC/PAC, three 527 drives, and an HMI ??
A friend is encouraging me to study for the CCNA exam so I have been digging into the network stuff a lot, which is good probably, it will help.
Bill
Bill
