Changing ML1400 IP Default Gateway
Bullzi
Jun 2012
Colorado
1,530
Hi Guys,
I have a ML1400 at a customers remote location. I have a VPN into their network but I cant see the PLC, I can see the HMI just fine. I looked at what I had set in for the default gateway and I had fat fingered the address and put in 245 instead of 254.
Is there anyway to change the gateway via the VPN? Or do I have to drive out and connect up to the PLC?
Just wondering if any of you have ever had this happen and found a way around taking a long drive. :sick:
Thanks for the help.
I haven't tried that via the LCD before. I have never been able to change the IP settings from the ML1100 so I didn't think it was possible.
I do have someone on site that might be able to do it. Thanks for the info!!!
LCD/keypad access to the IP address, subnet mask, and default gateway settings is one feature that the MicroLogix 1400 has but the MicroLogix 1100 does not.
Worse than fat fingering the gateway...
I'm in Central California. The PLC was in Yuma, AZ. 8 hours away by car. Luckily I was able to fly in before we were done with the project. Whew.
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
262
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
501
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
101
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
303
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
225
