Interview question
sparky64
May 2003
Newcastle upon Tyne
127
At a recent interview, i was asked why data is transmitted using hexadecimal values.
I didn't know the answer, and the interviewer never expanded on the question.
Can anyone answer the above question, as its been bugging me ever since.
Cheers
Sparky
PS I didn't get the job!!
guess
Sparky,
I assume you are a regular electrician type? (like myself)
I would think that data is alway transmitted in binary but can be displayed in many ways Hex being one. Hex was used because it was easier to display on a 7 segment display than a long string of 1s and 0s yet could be more easily converted to binary than decimal values. But I'm sure there are going to be some more definitive responses from this crew.
Brian
Data on a bus, be it serial or parelell is transmited in binaary. Sliver has the right idea.
Hex is a differnt, more effiectnt method of displaying Binary data.
For instance each hex value (0-9,A-F) usually contains the value for 4 bits of binary data.
0 = 0000
1 = 0001
2 = 0010
A = bin 10 = 1100
F = bin 16 = 1111
FFFF = 65536 = 1111111111111111
The data is displayed more efficently, and easer to be understood etc..when programming in low level languages such as assembly, PLCs, etc. Just imagine the number of keystokes it would take otherwise.
As far as the bus, or board level components go, its all coming and going in binary.
Mike.
my understanding was this came about when everything was 8 bit.
The reasoning for hex was any number from 0 to 255 could be displayed using only 2 numbers.
ie. 11111111 in binary = 255 in decimal = FF in hex
I agreed with you. It help me to think about my ideals.
Pls try to keep posting. Tks and best regards.
....For instance each hex value (0-9,A-F) usually contains the value for 4 bits of binary data.
0 = 0000
1 = 0001
2 = 0010
A = bin 10 = 1100
F = bin 16 = 1111
Couple of minor errors here, Mike.
A = dec 10 = 1010
FFFF = 65535 = 1111111111111111
just so that no-one gets misled...
A = dec 10 = 1010
That, and 1111b = 15 dec = F hex.
But as for the original question, the only possible answer is "Because that manufacturer decided to do it that way".
Not all data is transmitted as hex period. Digitally encoded information may be transmitted over a serial or parallel link in virtually any manner of encoding.
Then there is also analog transmission, or pulse-coded modulation, or frequency.
That is a typical worthless interview question dredged up by some mouthbreathing seatwarmer in a human-resources department in a useless attempt to filter candidates headed towards a position the interviewer doesn't have the first clue about.
...That is a typical worthless interview question dredged up by some mouthbreathing seatwarmer in a human-resources department in a useless attempt to filter candidates headed towards a position the interviewer doesn't have the first clue about.
Feel strongly about this, Bob?
Steve
I went back in to edit it to 15 - but my ISP ditched me (yet again!).
Top marks for .... "That is a typical worthless interview question dredged up by some mouthbreathing seatwarmer in a human-resources department in a useless attempt to filter candidates headed towards a position the interviewer doesn't have the first clue about."
I too would like to salute you for this exquisitely succint quote. Best laugh I've had all week :ROFLMAO:
(in answer to the original question - allbeit, asked some 7 years ago - I always thought that we used to use Octal a lot because computers dealt in 8 bits and then when we progressed to 16 bit computing, Hex - base 16 - became the best way of representing the data)...
Some interviewers make you wonder.
I have been in some interviews, where it was not only management, but sometimes also an engineer or other automation person. Sometimes these people will bring up a question, which is something they just learned, or just used on a project, and are more interested in impressing management, then actually asking a pertinent question.
I was once asked if I understood 'Optic Logic'? I think he meant how optics control conveyors. My answer was 'Do you mean the difference between wiring and input cards for PNP and NPN'? I got a blank stare from him, as he had no clue what I was talking about.
Sometimes you have to interview the interviewers.
This is maybe off topic, but I just had an interview at Amazon and was asked to do this question. I was blanked in the head, was wondering if...
3,884
i was in an interview and i got this question what is pointer in S7-300 ? what is it used for ? can you do a simple project with it using ladder...
1,757
I'm tasked w/ coming up w/ interview questions for my customer for a plc programmer. I have tons of ideas, but I am afraid I may tailor them too...
53
10,435
What is the maximum integer unit for analog input of siemens 300 plc? pls help thank u in advance.
3,955
