What are your current safety practices with control panel startup & debug?
tspisak
Aug 2005
Corning, NY
72
I'm curious what everyone does (safety wise) for their initial power-up and debug of control panels with >240vac.
Do you suit up (FR shirt/pants, hardhat, earplugs, safety shield) to program the VFDs or to adjust a setpoint during debug of a conveyor?
Do you suit up to check the LEDs on a safety relay or pull a memory card from a HMI?
Are your AC panels ALWAYS closed during debug?
Are your standards/practices different during testing at your facility vs startup at the customers facility?
NFPA 70E appears to be written for electrical switchgear and motor control centers not for industrial control panels.
My typical panel is fabricated with finger-safe components (IP20), Class CC fuses in the disconnect and all motors(to protect both the wiring AND anyone working in the panel from arc flash) AND we never touch live AC voltages. On a large job I have had projects with a separate AC panel and a PLC/DC panel but that is rare for the project we have.
Should a 480vac control panel that designed to a certain standard allow lower degree of protection (gloves, faceshield, FR shirt, earplugs only required for metering AC voltages - no hot work)?
Today I was working on my project for school and we were using a power supply with 24V and we accidentally had the current at 0.9A. We heard a pop...
564
Hi all, I have been working on a project that requires me to measure the current across a 90 VDC motor of a medical device (similar to an...
26
1,590
HI i have a delta VFD M-series in the manual, in order to enter the motor rated current you set the parameter P,52 =the motor rated current my...
691
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
359
VFD is not tripping at higher current , resulting in motor failure . VFD Model : Make - KEB Type - H6- 10H6BBBB-21B0
520
