Siemens S7-314 MPI interface with Proface touch panel
muthu_buddy
Feb 2007
Singapore
17
I am new to using the Proface touch panel. Currently for a project i need to link a Siemens S7-314 PLC with the Proface 5.7" Touch panel (AGP3301-S1-D24) using MPI. I already have Profibus cable, Simatic PG connector of both 90deg and 180 available. I like to know whether i can use the standard siemens Profibus cable and PG connector to link between PLC and Proface touch panel. Or else do i need to buy the cable and Connectors from Proface? Anybody suggest me for the best solution for this.
The connection is simple. To communicate via MPI between Siemens PLCs and Proface screens, use some profibus (2 core) cable and the 9 pin d connectors with built in terminating resistors (Switch to "On").
You do need a 9 pin adaptor plug from proface between the d-connector and the touchscreen socket. They can advise you the part number.
Thanks for your comments. I thought the siemens PG connector can directly connect to the proface touch panel MPI port. So now i know i need the adapter from Proface.
P
Hi all. I have a CPU314 (no DP!) and a OP17. Is it possible to set the leds on the OP and read the keys when both are connected over MPI ...
4,100
P
I have established an online connection to a machine using an S314 processor. I am using an mpi connector and simatic manager. The online...
247
Hi guys... been a very long time since I've posted... I have a few machines here from the Czech republic that came with siemens plcs in them...
1,938
Hi all I have a cpu314c with a 5ai/2ao unit, I can’t get any reading within my program. I have tried with the simulator and the program works...
2,339
Good day I recently Changed a screen on a Machine from OP7 to KP400 Comfort using TIA portal v12. since the change the communication is a bit of...
2,404
