Problem connecting to CR30 Safety Relay via Studio 5000
Mel_24
Feb 2016
New Zealand
Hi all
Was wondering if you guys were able to help. I am onsite trying to program a 440C-CR30-22BBB Safety relay. Using the following pdf and trying to follow the instructions to add the CR30 Safety Relay to the I/O configuration. (Chapter 13, pg 114).http://literature.rockwellautomation.com/idc/groups/literature/documents/um/440c-um001_-en-p.pdf
Problem is that I can't change the module to revision 9, even after I downloaded the AOP for version 9.004 from the Rockwell download center.
Any ideas on how to do this would be awesome as i am wasting too long on this at the moment.
Hi
I think you need cow software
Are you using ver 26 of Logic as I think you need that I get the aoi to work
Donnchadh
Just for anyone having the same problem, you need to have AOP v2.1 or above. Was meant to come out summer 2015 but has been delayed. Unfortunately all the manuals say that it is already out. Thought i would let everyone know instead of wasting half a day.
Hi
So the only way still is using ccw is that correct?
My local rep has been telling me about this aoi for at least a year now but
He told me it will only work with v26 and up
And also that ver 10 of ccw is due out this month to fix a issue we have
With some units losing their program on power down
Then again ver 9 was meant to have fixed it also
Donnchadh
Hey Donnchadh
Unfortunately it is the only way at the moment from what i could gather.
From reading the latest product manual, it says it should work from studio 5000 v21.0 or later.(Chapter 13, pg 113, IO Messaging, link is above) but it definitely needs AOP V2.01.
From what I could gather from speaking with the AB tech support is that something really bad must have happened because all the manuals and documentations have be changed and talk about AOP 2.01 in detail but when I asked Tech support about it he said it wasn't out and no one knows when it should be out. Even got my local rep to confirm it.
It is worth saying that i have only just got a job as a graduate PLC engineer a month ago but if you do find AOP V2.01 please feel free to drop the link
Cheers
Mel
First of all Hi, nice to met you all. I have a problems trying to control my PLC's (1762-L40BWA ser. C and 1763-L16DWD ser. B) with the Panelview...
5,132
Hello! We have one Omron NT11-SF121B-EV1 display and CP1L PLC. I want to connect this display to computer and upload graphics with NT-series...
2,363
Greetings i do have a new Siemens PLC station with 314 CPU 1DP i try to connect using the PC adaptor Cable USB A2 i do have the Error message...
2,251
Dear Members: I am new to Twincat System. I am working on a project. I have connected CX9020 with my laptop through ethernet cable. I was able to...
4,631
Hello, I am using Unity Pro S V8.0 and Vijeo Designer V6.2, both are not licensed yet. I followed tutorial video from youtube but I still cant...
5,335
