Hi Speed Counter
andrew452
Feb 2017
tx
Hello all. I'm in need of some help with a 1769-HSC. I've never messed with a HSC and am not really sure what I'm doing. I am trying to use it as a totalizer. The meter I'm told is 0-5khz. Thank you is advance.
I typically set them to a roll over counter then build a master totalizer. Then when metering grab a snap shot of the totalizer and open the batch valve until it get to a SP-Preact number and close the valve and wait a few seconds, then report back the totalized batch amount.
We usually use the Spectrum 8 channel HSC because you get more bang for the buck.
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
94
i am bench testing a 1734 -VHSC24 Point I/O High Speed counter module, i cannot find any examples of wiring the outputs from the module. does...
1,497
Hello guys, I have created a program where I count the high speed inputs of a flowmeter and create pulses per second to check the flowrate. Next I...
1,822
Hello to all, I don't have to much experience in the PLC. I'm using the Studio 5000 v32.03 We are trying to measure the length of a product, in...
1,168
Does anyone know how to set the output window on-off values on the fly without having to inhibit the module? I could of sworn when I first started...
2,434
