Shaft speed counting with Micrologix 1100 high speed counter.
tribologist
Oct 2006
Connecticut
I am a very inexperienced PLC programmer. I purchased a Micrologix 1100 and the RSlogix to play with last year. Recently I found an application for it and I like to put it in use.
I like to use it as a watchdog in a bearing test rig. One of the things I like to prevent is over speed conditions.
I have a 2/rev PNP signal and I operate between 0 and 2000 rpm. I am trying to find out how I can use the 20 kHz high speed counter to measure the shaft speed withing 5% of actual speed.
Any one out there with experience with the Micrologix HSC function that have some ideas?
Ulf
[email protected]
Look at the HSC function in the manual. It gives a good example, search the forum under AB HSC counter and encoder. There are lots of links. Try to understand how it works first.....
Ulf...
here is one of the applications i worked on before...it uses micrologix1000 plc with high speed counter.
Thanks bio PLC. I looked through your program and I found how you used the counter. I am quite comfortable with using it that way to count to a given preset. The one I have an issue with is to measure frequency or period time. I need to try to dig through the documentation and try to find a way.
Do you think it is easier to measure period time than counting number of passes over say 6 seconds?
Ulf
bioplc,
I think I need to use HSC to count pulses from a PWM output on a MicroLogix 1200. The PWM is being used to send a varying frequency at a fixed 11% duty cycle to a set of snowmobile gages. I don't believe that I can get this information for a software count; I think I need to wire it to an input set-up for HSC in parallel with the gages under test. The goal is to determine accuracy of the gages over the speed scale. The customer wants 2519 pulses to equal 1 mile. I was thinking of setting the HSC up for this count and this would increment another counter each time it's done -- which would give me a mile count (up 32,767 miles). Question is... how do I set-up the HSC in a 1200? I can't find any info in the manual.
thx,
ron
Good Morning , We have a large machine with a number of shafts , and I would like to monitor those to make sure they are constantly...
2,125
Greetings, I am trying to get a Incremental Shaft Encoder (white pages attached) to count on my HSC in my 1200 project. I have assigned the first...
17
12,865
I've been trying to measure shaft speed with a 120 tooth speed wheel, a bi-directional powered pickup, and a 1756-HSC/B counter card. I am...
3,291
I have an application coming up that will have 2 oil shear brakes on opposite sides of a differential. I need to be able to control a speed...
1,726
Hi, I want to do an electronic line Shaft with Yaskawa A1000. I think a must update firmware. Do is a user that have a firmware for this? I...
775
