How To Make Connection With Allen Bradley Cpu En The Sst Profibus Scanner???
sinanawchi
Feb 2005
Hallo, I need some help with the conection for allen bradley CPU and sst profibus scanner. I want to go with the sst scanner to the siemens dp/asi link an then to ASI of course but i can't made a connection with each diveces. If you no some think about it pleas help me. Thanks,
AB CPU --??->SST profibus -??--->Siemens dp/asi20E ---->ASI
Sinan
sinanawchi, you need to describe what you have already done before anyone can help you troubleshoot.
There is sample logic for getting data betweeen the SLC-5/04 and the SST-PFB-SLC module that is included with the module and is also downloadable from SST's website.
You posted before about the SST Configuration software; have you correctly set up the SST module's Profibus interface to communicate with your ASi gateway ?
Good Morning, I got an IMO HD2 inverter with 2 slots and on the first slot I put the ethernet module (HD2-E-ENET) and the second one is free...
1,281
Hello all, Who have links for documentation,- how to connect Allen Bradley 3 phases VFD PF753 in test purposes using only 230V. Approximate...
1,570
Hello everyone, this might be a stupid question but I will still ask lol I just start working at a new place and all the PLC programmer get...
1,340
Hi There, I have an application in mind using an existing Allen Bradley Micro 830. this PLC does not have on board Ethernet communications and i...
2,517
Hi all, I have an ihm and I need to connect this with compact logix PLC. In factory talk this communication works well (factory talk and fisical...
2,343
