HMI Connection Over Modbus Allen Bradley
combatwombat5
Dec 2015
belfast
Hi There,
I have an application in mind using an existing Allen Bradley Micro 830. this PLC does not have on board Ethernet communications and i need to add an HMI to this Panel. I am using the new panelview 800 2711R-T4T and using the Serial ports to communicate over modbus. i will need the screen to work as an input to the plc entering two values of both length and quantity. can this be done over modbus comms with the PLC working as the master? has anyone done something similar or have any examples? Thanks in advance.
I think with those models you could go with DF1 if it's just a point to point connection.
I have found a setup with the HMI as the master and the Micro as the slave but it looks like it could be reversed as the micro supports modus master, the specs on the hmi were a little vague state only Modbus rtu so I am assuming it can act as a slave. but from what I am reading it looks like it can only run as a master.
here is the link:
https://www.google.ca/url?sa=t&rct=...ew.doc&usg=AFQjCNHVkm6SsuyiZt50HDN5GDQYbZNYyw
http://www.staveb.ch/downloads/cn01_configure_micro800_modbus_comms_pvc_20100.pdf
Hi gents I have weintek HMI (MT6070IH) and s7-200 plc cpu 224 and vfd which supports rs485 modbus rtu communication. The plc has 2 ports, one...
794
Hi! I'm an intern and a newbie in the field of automation. I was given the assignment to learn and program a PLC and HMI together. PLC: Delta...
1,977
Hi Experts, One of our clients, until recently, could connect remotely via the internet to a Siemens TP1200 Comfort HMI via VNC and **** Cosy...
1,585
Ye..llow everyone! I need some help on this: I have TIA project with an Siemens HMI connected to an OPC server. This HMI has the file name...
966
Greetings, Does a touch screen HMI require serial or ethernet connection only? Can I connect using DVI-D or DVI-I port? I know that industrial...
3,194
