Slow alarms in FactoryTalk View SE Alarms and Events
Marie1982
Feb 2007
House
121
I compared the two methods for displaying alarms in FactoryTalk View SE (which are the old HMI tag alarms just like RSView32 or the new FactoryTalk A&E). I put the two alarm summaries in the same display and configured a tag to give an alarm in both summaries. The alarm in the old Summary comes up instantly, but in the FactoryTalk A&E, it takes about 7 seconds to show up. And I'm using a memory tag, what will it be when I will use PLC tags???
Anyone experienced the same problem or know the solution???
Marie
I didn't tested with memory tags, but in device tags works without problems thruogh the Ethernet network. I have all alarms in the ControlLogix with ALMA and ALMD functions and read the alarms status with with FTAE. The only thing that I still can't make is the historic of alarmas and events with SQL Server Express.
Hello all, My customer is using FactoryTalk v 6.10 and has this re-occurring problem. The system usually runs fine. Occasionally when opening...
2,245
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
151
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
88
Hi, I have some problem with View Point which I'm using to manual control of conveyors. On begin when in network was only PLC and HMI View Point...
73
Hi. Importing a 2014 aapck in 2023: no problem using it, adding windows, works very well, no problem whatsoever. Creating a new project: as...
752
