Automation Direct 12vdc plc and a 4 channel 4-20ma input card all 12vdc
Rmiller
Dec 2002
Vancouver, Washington
25
I am trying to setup an RTU with solar power and am trying to keep the power consumption low. This will have 3 pieces of equipment that I am trying to match voltages on.
1. The radio can be either 12vdc or 24vdc,
2. The data logger is 12vdc only,
3. And last is the plc which has to be an automation direct slave with a 4-channel 4-20ma input card.
I cannot seem to get a 12vdc powered analog card for the plc and was hoping somebody could help me with this.
I have thought about setting up everything 24vdc and using a 24vdc to 12vdc converter for the radio but thought that this would draw more power. Is this true and does this sound like a good solution?
My 2 cents
Have Two 12 V batteries charged by the solar panel and use both for your 24V and one for your 12V radio.
I agree just use two 12 volt batteries in series, use the negative side for both negatives and pick up off the common point between the two batteries for 12v and pick up off the other side for 24v...
Tom
either or doesnt really matter but to keep things simple i would just use a single 24vdc charger cheers tom
A 24 volt charger is of course the simple solution but if the radio is ran off just one battery then it will more than likely need more of a charge than the other and one charger will then not charge properly. I recomend two chargers.
I am currently using some RTU's from www.IClinks.com that run on 12v. Iam not sure if the requirement for a Automation Direct PLC isa requirement
There is a wide range of DC to Dc Voltage convertors out there with efficency of 90+% to get from 24v dc to 12v dc.
Even poor old Radioshack should have a IC regulator chip to get you to 12v, efficency would be a lot poorer tho
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
119
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
136
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
565
Anyone tried Automation Directs new CM5 HMI. We've been the EA9's for a few years now with minimal complaints. A few failures here and there but...
17
1,588
I'm using an Automation Direct GS20 VFD for the first time and I have a question for the Automation Direct gurus regarding the recommendation of a...
1,100
