Factory Talk View SE Client novice question
briana banks
Jul 2005
242
Hi All
I dont have the sofware, so asking a small question.
when installing FT SE Client,on PC, does it require sharing folders with the server for the location of the project file ?
or you just give it the IP number of server.
Many Thanks.
No shares are needed, the client is basically a customized browser. All you need to do is point it to the FactoryTalk directory hosting which refers to the proper application.
Hi & thanks for replying.
will this solution work well (fast enough) in WAN i.e. through switches and routers?
does the client uses caching to store the images?
It should work fine, as long as latency isn't horrible.
Yes, the client does cache displays, and can continuously updated cached displays if desired (configure on the display itself, "Display Settings | Cache After Displaying | Always Update". This can affect performance if memory is low.
28
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
320
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
289
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
589
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
364
