Directly buried FO cables vs Cables running in Underground ducts
Charbel
Jan 2012
Beirut
307
Dear,
cables running in underground ducts offer several advantages (technically) over the ones running in directly buried such as FO cables running in underground FO ducts will be easier to pullout in case of a fault in the FO cables.
do you think of any other advantage? I am trying to convince client for this option.
thank you!
charbel
Isnt that enough reason ?
You dont say if it is soil or concrete.
For soil, you have to have special cables that are suitable for exposure to the environment so they would be more expensive anyway.
For concrete, well then you have a system that cannot be allowed to have a failure - ever.
Requirements change over time that nobody can predict. Perhaps they'll need more fiber strands in the future. Perhaps they'll need a different type of fiber in the future. Put it in conduit and changes become nearly trivial. Add a second unused conduit in your ditch while you're at it.
believe it or not,
fiber cables can and do go bad.
most of the time it is the ends, we re-terminate, we have 2 pair - dead.
Say you did do a direct burial cable with 3 pair.
3 years later, you need another 2 pair.
you incur the same costs again versus pulling a new set of fibers!
you also risk tearing up the existing fiber.
we run everything in conduit and it's paid off big time.
james
Dear, The application is that the PLC will be running a pump for distributing to a reservoir where level sensor/switches are included. The level...
2,683
Hi; First of all, I am sorry that my post is not relevant with this forum. I have recently purchased Samsung cell phone. I have alreay saved...
75
Hello everyone!!, I may be asking a newbie question, but I want to be sure of that. Can I run a PLC program directly from the SD card? I mean, I...
188
When using System Platform, I can use the object viewer to directly manipulate attributes/tags/whatever. When I have a standalone InTouch...
992
As I understand it, Codesys is the foundation for many different OEM branded HMI software packages. What are the advantages and disadvantages of...
1,644
