Dear,
The application is that the PLC will be running a pump for distributing to a reservoir where level sensor/switches are included.
The level sensor/switches are monitored from a remote IO
I need to run Fiber optic cable for connecting the PLC to the Remote IO together separated by a distance of 1.5 km.
I have two options, either I run FO cable through a UPVC duct with using manholes, or put it directly buried (less cost).
Clearly FO cable running trough UPVC duct will be better option (easier to pull if needed) but higher cost due to manholes and UPVC duct.
for directly buried, FO should be armored.
I am not good at estimating cost, but I believe it would cost around 8000 dollars more.
thank you!
charbel
thank you!
charbel
