FO directly buried or through duct
Charbel
Jan 2012
Beirut
307
Dear,
The application is that the PLC will be running a pump for distributing to a reservoir where level sensor/switches are included.
The level sensor/switches are monitored from a remote IO
I need to run Fiber optic cable for connecting the PLC to the Remote IO together separated by a distance of 1.5 km.
I have two options, either I run FO cable through a UPVC duct with using manholes, or put it directly buried (less cost).
Clearly FO cable running trough UPVC duct will be better option (easier to pull if needed) but higher cost due to manholes and UPVC duct.
for directly buried, FO should be armored.
I am not good at estimating cost, but I believe it would cost around 8000 dollars more.
thank you!
charbel
Dear,
thank you!
charbel
What's your question ?
Only you know what your budget is or what will work best for the run, you could use armoured cable, just make sure you run at least 50% more cores than you need as the price difference between 8 and 16 cores is not much.
It also depends on what speed you need, you could use twisted pair and get Ethernet extenders to do the same job for less cabling cost.
A good quality direct buried armored FO cable is just fine. Unless you forsee other services being pulled to the same site, skip the manholes. Also, as tragically1969 said, put in more strands than you need.
At 1.5km distance, unless there are severe obstructions, you could look at unlicensed 900Mhz FHSS radios (assuming these are legal in your country). Take a look at the J series radios from Schneider. I have an application where I poll remote IO using modbus TCP over a link like this and it works great. I only poll every 5 seconds but that's plenty fast enough for reservoir level measurement.
If free band stuff is no good then take a look at Schneider's Q series radios. You'll need a licence but generally the cost for that will be much less than for cabling.
There are plenty of other radio options too, as OkiePC says take a look at wireless IO. Elpro is very good, I use them often.
Dear, cables running in underground ducts offer several advantages (technically) over the ones running in directly buried such as FO cables...
3,777
Hi; First of all, I am sorry that my post is not relevant with this forum. I have recently purchased Samsung cell phone. I have alreay saved...
83
Hello everyone!!, I may be asking a newbie question, but I want to be sure of that. Can I run a PLC program directly from the SD card? I mean, I...
198
When using System Platform, I can use the object viewer to directly manipulate attributes/tags/whatever. When I have a standalone InTouch...
1,009
As I understand it, Codesys is the foundation for many different OEM branded HMI software packages. What are the advantages and disadvantages of...
1,657
