Question regarding signal conditioner,active->passive converter 4-20mA
Fseipel1
Aug 2017
Ohio
I need to go from a powered 4-20mA output (i.e. transmitter supplies voltage) to an Allen Bradley HART input card 1756-IF16H. I cannot set input card up 'single ended', because it already has inputs on it & I can't afford to lose half the inputs. So I'd like a signal conditioner that will basically convert active-->passive mA, and preferrably, ALSO pass HART signals. This is for a Micro Motion coriolis flowmeter. In past, I have used Rosemount 'Tri-Loops' to achieve this, but I really don't need to split the signal into 3 non-HART outputs; I would prefer to just pass it as HART and read temperature, density, and flow rate as HART.PV, HART.SV, HART.TV, etc -- if anyone can supply make/model of such a converter it would be helpful.
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,024
I haven't had to tune a PID loop in a very long time. It's actually a PI loop for a pulse width modulation s.v. What was the name of that tuning...
4,114
Hello, I have a question regarding the analog output modules on a AB Micro850. I'm not getting an output to my valve and when I put a meter on it...
1,538
Happy new year everyone. This is more of a Electrical engineering question than a PLC one. Can a Motor and a VFD that is rated for 240/480...
29
9,920
This may be a simple question. I understand the concept and application of analog modules (i.e. Compactlogix) for transducers, and outputs for VFD...
2,087
