Multiple Profinet IO systems?
ahuberee
Jun 2015
Atlanta
I have two PLCs on a network. One of which is the Primary Control PLC (PLC_1). The other I wanted to use as an I-Device to serve up signals which are pulled and processed from other networked Profinet IO Device Gateways (PLC_2). PLC_2 only has one network card.
PLC_1 IP: 10.1.1.100
PLC_2 IP: 10.1.1.101
IO IP: 10.1.1.102
I have configured my IO Device Gateways. I've also created a Transfer region to/from PLC_2 to/from PLC_1. After doing this TIA Portal creates a "Profinet IO System" for PLC_1. All devices I connect up to the network automatically become assigned to PLC_1 so I cannot access the IO Device at PLC_2.
Is there a way to add another IO System where PLC_2 has access to the device and still have a transfer region where I can send data to the Primary PLC_1?
I think I figured it out. After connecting the IO Device to the network, I had to delete the Profinet System Connection from PLC_2, then assign it as the DP Master by right-clicking the network. This separated the two Profinet IO systems (one for PLC->PLC transfer) one for the IO device.
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
145
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
486
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
315
I'm trying to use DTM browser to make make modbus poll from RTAC. I'm able to get the points in first poll object. But not able to get anything in...
125
Hello, I encountered a problem with the kinetix 6500 drive, error code s22, loss of 3 phase voltage. After disassembling and replacing the thermal...
167
