Mitsubishi GOT GT Designer 3 Recipe: can't add more than one recipe
dbanks
Nov 2017
Tucson
Hopefully someone has had more experience in this than I have.
I was tasked with making a recipe function for a project. I've done so based on some of the example programs they had online. Here comes the problem:
Everything works just fine as long as everything is a signed Bin16. Problem being, two of my numbers have to be real.
After getting all of the right specifications with the real numbers included, it only lets me add a single recipe within the recipe settings. If it says 1 under record numbers, everything works all fine and dandy. If I change that number to ANYTHING else (to account for the fact that we'll need more than one obviously), it immediately goes to "cannot read/write recipe". Switch it right back to one - VOILA everything works again.
Does anyone happen to know what could be going on here? In the middle of an update, but I'm not that far out of date so I'm not feeling to confident that's the problem.
Any help would be greatly appreciated.
You have to delete the Recipe File and have it rebuilt. Because you changed the formatting of a record.
Hi Guys, Anyone that have experience in using GOT GT Design / GT Soft Touch (Screen software)? Thanks
14,439
Is there an output or something that is similar to a screen saver, but you can use in the plc to know when the user is actively using it...
517
Hello, I have a GOT 2000 that is dead and only have a GOT 1000 spare at the moment. I have converted projects up from 1000 to 2000 before, but...
821
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,323
I am trying to connect GOT-A953-tbd HMI with Nittoku NSC30. Actually, earlier GOT-A953-tbd HMI was used to communicate with Nittoku NC350 and it...
1,401
