problem of connection between a TSX Micro and Vijeo Citect v7.20
abdobouka
Dec 2011
el jadida
I have a problem in terms of inputs and outputs, when I create a tag for a variable% MW1 and I run it . i had a BAD display for my tag. So my problem is the fact that I can not implement the correct configuration in vijeo citect of my API TSX MICRO knowing that I use a serial cable (RS485)for communication between the PLC and a PC and software PL7 pro as PLC. is there any system requirements for this kind of problems.
I have not used vijeo - check that there is no space inthe tag name %MW1
Also confirm that it can talk directly to the processor
it may need to use Modbus - so %MW1 will not work as a tag.
HI every one , I'm trying to connect two cpu's in siemens step 7 I followed all steps7 in this video https://www.youtube.com/watch?v=-qnvwz8nlRQ...
2,655
Hi all, I am trying to load a program to a simatic panel I have set up the ethernet communication so that both my pg and my panel have the...
2,402
hello. i have one problem...this project work fine for one month and when i start the computer it works fine but now he show an error in...
976
Hello Everyone, I am being unable to connect my laptop & GE Quickpanel (IC754VGI12CTD) through an ethernet cable. But I could connect the same...
18
6,477
Problem with connection between TP170A and PROTOOL the project I'm trying to download for TP170A from configuration computer through Serial...
3,701
