Firmware Incompatibility RSlogix5000
guenwyver
Jan 2021
arizona
I am having issues going online with a PLC in RSlogix5000. I need to pull the file from the processor for backup before we take the cell offline. We have never been online with the cell before but outside vendors have.
When I try to go online, I get an error that says "The controller I requested contains firmware revision 32.14. RSLogix 5000 support for this revision is not installed." I have versions 17-20 installed on the computer and the Rockwell download center comparison says they are compatible. Am I missing something that I need an early version? How do I know which version I need installed
In order to go online you need to have installed the (major*) software revision matching the firmware of the PLC in question. Since the controller has firmware 32, you need software revision 32.
I believe you should be able to upload and save a backup regardless, but your version must match to actually go online. You may have issues restoring the backup without a v32 installation regardless.
*There were some broken compatibility issues for minor revisions in v20 & 21, I mention them here for completeness, not because they're relevant to the current issue.
I was looking at RSlogix 5000 versions and couldn't find it when I looked earlier. Completely forgot about the Logix Designer section of the downloads. I figured I was missing something simple. Thank you
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
70
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs...
256
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
106
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
479
